1 - 20 of 25 Posts
ConqSoft said:
Yeah, the PitBull Spooled Stand BARELY fits the 1000RR with the standard Pit-Bull Spools.
Conq, could you explain that to me? The wife has Pit-Bull spools (not sliders)on her 600 with a Pit-Bull stand with no issues. I have Pro-Tek spools (not sliders) on the 1000 and a Pit-Bull rearstands with no issues. If I was to switch spools between machines I would have issues?
My brother has Pro-Tek sliders/spools on his RC and they are a tight fit on the Pit-Bull rearstand.
NinerPilot said:
I think any of the nubbin spools are fine on the RR. But the slider spools stick out a bit from the swingarm not letting the pitbul grab it.
Chris
Width being the issue? Then yes, the RC is a tight fit with sliders and a Pit-Bull. Sliders do not fit as deep into the "V" although that is a lesser issue IMO.
Chris
You can't adjust the width of the PB? With my SS rear (spool and swingarm) adapter you can adjust the width. Or am I just not understanding the problem correctly? :huh:
RRWANTR said:
Holy crap!! It's that much wider than the 954.....holy moly rocky.
Mine is very close to maxed out with regular spools as it is.
I removed the washers under the bolts holding the tops on, thereby gaining about a 1/4 inch in overall width between the "V"s. (RC51)
1 - 20 of 25 Posts
