1 - 9 of 9 Posts
· Registered
I have a 96 Shadow ACE 1100. Lately it has been sputtering, under a heavy throttle condition, with a loss of power, and low fuel mileage.:mad: There is soot in my tail pipe tips also. I removed the air filter and found oil puddled in the bottom of the air filter housing.:confused::huh:
· Registered
it sounds like blow back. generally the cause of oil blow back through the carb is an after market cam, or in appropriate exhaust. in the event of an aftermarket cam, or even an exceptionally worn cam the intake valves are closing too late and when the engine fires its forcing oil, fuel mixture back through the carb. the problem is likely NOT to be your carberator. at this point since you get bad lugging I would look at the canm first and check all your lobes to see if it needs replacing, especially since you are getting soot out the backside. I would also (if your going to dig in and look at the cam) check thye cylinders sleeves and rings to make sure your not getting excessive oil bypass from your piston rings.
Poorly designed or inappropriate exhaust systems can also increase the amount of blow back, sometimes enormously. The worst offenders are overly long, open straight pipes.
I hope this helps.
all engines have a little blowback at various rpms but most of the blowback generally gets trapped in the breather and finds its way back through to getting burnt at higher rpm.
· Registered
A little oil in the air filter housing is normal. Throw a couple of sparkplugs in maybe. They could be fouled. You eliminate that being the cause. The bike may need a good run after to blow out crap if you ride slow around town especially.
Anything else happen prior to this problem like sitting for a period and wouldn't start and so on?
· Registered
From the sounds of it.. It isnt just normal oil in the housing.. I personally have never seen oil puddle in the filter housing. I would think there is a little more to it.
I would still try changing the spark plugs though yes. That is cheap and never hurts to do
· Registered
I agree, almost every bike in the world gets some blow back, and they usually retrieve most of the blow back during optimal RPM's, or at least the blow back ceases at a n elevated RPM, 3000+ slight oil puddling shouldn't be confused with excessive blow back.
· Registered
I have a 2009 Honda 750 Shadow that i just purchased. In the last 4 years it has not been used much and only has 8000 miles on it. When I throttle up it cuts out at 1/2 throttle and sometimes dies. I have checked the plugs and they are clean. Fuel tank had been drained and 93 oct fuel has been ran in bike for about 100 miles. What else could be causing this problem.
1 - 9 of 9 Posts
