I am getting ready to replace my starter, do you HAVE to drain the coolant before doing this?
The manual says to do it but I can't see why I would have to. Any knowledge would be helpful.
Thank you,
Kristin
which model do you have? on the 96-97, it is not necessary. can you get to all the mounting bolts without removing the radiator/hoses?
Is this the only reason I would need to? Is to get to the bolts? If so I can move them out of my way easily enough in order to not have to drain
it. I have a 03 954
Thank you.
