Hi I am new here.
Very information, I see.
Could some help please?
The bike wont start / fire.
It would if jump & push started.
An identical reference bike was used by the mechanic,
swop all electronic stuff,
>> the reference bike would start on either set of the stuff,
>> the problem bike wouldnt with either.
Baffling.
Cheers.
The engine kill switch on the right handlebar is a problem area. Sometimes a loose or bad connection. Wiggle it or take the cover off to make sure the wires aren't severed off, rusty, etc etc. Also, check to make sure the switch by the kickstand is ok.
i had a similar problem,check to make sure you dont have a broken earth wire,have you snagged any wires anywhere....check your starter relay and batt connections........
