1 - 2 of 2 Posts
I just replaced the Clutch on my 99' cbr F4 and since then it doesn't want to run. At first I thought it was the spark plug so I got them all replaced because they were black but that didn't help. Then I thought maybe the fuel pump needed replacing but the spark plugs are wet when I pull them out. Each time I flip the starter switch it sounds like it wants to start as long as I hold the throttle just a little to keep the starter going. Had it running once but it sounded like it was only getting fire out of one cyclinder because it was pulsating. Went to start it while holding the clutch and putting it in first and it seemed to want to pull forward so I have to adjust the clutch cable but that shouldn't bother it while in neutral. IDk what to do with it? Could it be the spark plugs not getting a good ground or maybe needs new wires to the spark plugs? Like I said, they were wet with gasoline...
1 - 2 of 2 Posts
