1998 CBR 600 F3
Bike was garaged for 5 years, in really good shape at 10k miles.
removed the carbs, cleaned the bowls and jets.
air filter looks good.
replaced the spark plugs (gapped), oil & filter, coolant.
filled with gas mixed with some sea foam.
wouldn't start (turns over, but no firing)
bypassed gas pump and raised height of gas tank.
fluid flows freely out of the tank.
Only fires if choke is full and I spray starter fluid into the front intake
revs high, then idles for a while, then dies.
acts like gas isn't getting into the carbs at all. Is there an easy way to check without taking off the carbs again.
