1 - 2 of 2 Posts
hello im new to the site and have a problem with my 01 929. i have traced down the wires to where the stator and regulator/rectifier connect. the white plugs have obvious heat damage to where the plastic has melted a little and the wire housing has a bit of damage. i guess my question is, i have tested both items and they test good, am i clear to put new connectors on and be good or do i replace them both or what. the bike has like s surge to it when running down the road. any thoughts out there would be greatly appreciated..
thanks
Your connector burned due to corrosion. Replace both. Ever washed your bike with soapy water or the pressure washer? That's where it usually comes from.
1 - 2 of 2 Posts
