1 - 1 of 1 Posts
My 1998 CBR 900rr battery kept draining. I checked the stator and rectifier using the manual and concluded the stator was out of tolerance. I replaced the stator and battery and using a multimeter I then got 1.2 ohms on the stator 12.42V on the battery. I then tried to crank the bike it makes no attempt to fire. It only makes a click in the starter box located to the right of the battery and a growl from the gears next to the stator. Confused what problem is now because all lights and displays are bright but it makes no attempt to spark as it did hours before replacing stator.Suggestions???
1 - 1 of 1 Posts
