Which steering dampers will allow a stem stand to be used? I know my Scotts won't.
Ohlins and any other piston type for the most part will !
SS
Stem stand for what use? If it's radar or GPS, Stem stand makes a brake resevoir mount. Legal speeding makes a windshield mount for 'dar.
booth23 : Stem stand for what use?  If it's radar or GPS, Stem stand makes a brake resevoir mount.  Legal speeding makes a windshield mount for 'dar.
I'm thinking about adding a detector.
SS, Some of the piston types cover the hole where the mount will go.
I thought the brake resevoir mounts were prone to breaking?
booth23 :  Legal speeding makes a windshield mount for 'dar.
it wont work on a 954 with a stock windscreen. You need about 1.5' more to clear the brake res.  The DB will do the trick.
the ohlins damper i just got wont allow a stem stand, unless it makes a radical angle from where it mounts......the ohlins hangs about 2 inches over the hole.
Went through the same thing.
You need a Matrisse (sp) damper with the triple crown center hole nut drilled out to allow the stem stand. I run this setup with a Valentine 1.
Mako : Went through the same thing.
I would think that a hyperpro would do the job
