Suggestions anyone??
1458 Views 4 Replies 5 Participants Last post by  spina220
The previous owner of my bike used to do wheelies. I believe he would pop the bike up when shifting from 1st to 2nd. I believe one of the shift forks maybe bent because sometimes it doesn't drop into 2nd gear just right or it may slip out. I can re-clutch the bike and hit the gear again and it will usually drop into place. It can be dangerous while making turns though if I'm shifting from 1st to 2nd. I'm going to have the forks fixed, but is there anything else I should beef up while they have it open? Or are there any upgrades you all would do or suggest since they have to go in? It's an 2002 cbr 600 f4i. Thanks
sorry to hear that but you might want to do your research on undercut of the trans.
Get the clutch checked and transmission for wear since the things opened up already
Just changed brake pads and has Brand New Bridge stone Battlax front and rear tires with about 98% tread left on them.
HUH?
