1 - 2 of 2 Posts
Hi, coming to rebuilding my 918, and with the swing arm collar circled in picture, wondering if anyone has experience with fitting them, what does the lip near the end do, as the diameter of the shaft is too big to fit through the centre of the bearing, the lip does not come in contact with it, has diagram got it wrong? cos if it is turned around it then fits into the needle roller bearing at other end, and does it really need this lip, thanks in advance
It looks like you need to fit the opposite ends bushing in first, then just hammer it into the bushing? Since it's a pivot point grease would be important.
1 - 2 of 2 Posts
