1 - 20 of 25 Posts
Back in November 2012, I got wind of a chain lubrication device called the Grease Ninja. Seems like I watched a youtube video of it, and thought it was worth a try, especially at only $15.
I got the impression that Tom, owner of Grease Ninja (and maybe My Space? :D ) was a start-up who had a good product that was not just another 'better mouse trap'.
I'm really glad I bought it, and can't believe I waited so long to try it out. The only reason is because I was procrastinating rigging the apparatus to the spray can.
That was easily tackled in about 3 minutes.
You guys and gals, this thing is a no-brainer! :)
This simple little plastic block is engineered just right to do exactly what it's supposed to. It comes with various straws to fit different size spray nozzles, that’s handy! And it allows you to hold the can straight up for when your spray can is almost empty. The Philips screws: take them out and blow air or WD40 through to clean all the ports. This is a well thought out design. imo.
I think I'll make back the $15 this year in saved (premium high priced) lube. The first time you use it, you'll see how easy it is to get adequate coverage without ANY overspray and no more than 5 or 6 drops of waste.
My endorsement is completely voluntary - I have no interest in Grease Ninja.
They just make a product that really works and is simple, fast, and very cheap.
GN Products
- It takes a few seconds to figure out to turn the wheel moderately slow.
- This is all the spill I had. Next time I'll have half that or less.
- My chain is a 520, this picture gives a visual of how well the ports line up with the Orings.
They offer another size for 525 or 530 chains. Even bicycle chains. If I was still mountain biking I'd get one for it too.
GN Products
mayb u can gv me the exact dimension i can replicate it using my 3d printer which is whole lot cheaper.
Yeah, we'd love to help you with Patent Infringement......NOT
Buzz off!
  • Like
Reactions: fj1200rj
I would assume that it is actually a Teflon block and not merely a hunk of plastic... good idea actually. Like Kevo pointed out.. not having overspray all on the back wheel and tyre is a lovely thought =)
Buzz off!
Here is my cheap ass method of chain lubrication without over spray. I have taken a used paper towel roll and slit it length wise. Then install it over the chain under the swing arm and spray away through the length of the slit. I'll take some pic's and send the dimension to nder.
lolxx u guys should understand why i asked the dimensions.. im located in asia where apparently the currency sucks i have to pay like 40bucks when i can use a 3d printer to make this in jus few bucks anyways no worries i have figured it out and well my design works n its awesome thanks for the shitty comments jdoni Jaybird180
You're welcome. Anytime!
Hey, just trying to help out :idunno:
Irregardless of currency valuations in Asia, these are usually free although hard to come by at times.
Length 14"
Inside diameter 1.5"
The glue strips are optional
JDONI- I think we might need a demonstration of the sophisticated device in use....a YouTube video???
Here is a product I bought over 20 years ago, haven't used it in awhile so I couldn't find mine for a picture, that's why I posted this guys video. It did contain most of the over spray, I just haven't seen it since I moved 10 years ago, lol. I don't know if it's still for sale, but I doubt it, all I could track down were you-tube videos. It has plastic bristles on the inside to brush off the crud, but I used to clean my chain first and only used the oiler on a clean chain, just so I wouldn't have to clean the oiler every time. Oh, and I used PJ1 chain lube, not WD-40, nor did I have the problems this phuktard had making it work. I used the string it came with a looped it around the foot peg, but then again I'm not a 'Busa genius! Sometimes you have to be smarter than the tool.
  • Like
Reactions: nder
Yea, like which way does the tube face :idunno::rotfl:...
Ah-So, :nerd the old "Chinese Blueprint" worked for you.
Can you please give me the exact brand of paper towels and the location of the store where you bought them so I can replicate it? I would hate to use the wrong brand and achieve sub-standard results, or God forbid, be sued for patent infringement, you'se guys are brutal! :rotfl:
heyy buddy im sorry i misread ur post .
I put my bike on rearstand, click it into 1st and let er roll. A towel behind the spray area soaks up the overspray.
Guys, cleaning and lubing a chain need not be an engineering challenge.
Heeza Y Zasch
am I the only one who just rides through the "rainbowy" puddles in the grocery store parking lots to lubricate my chain... :idunno: anyone...? Bueller...? :hmm:
1 - 20 of 25 Posts
