So I have a simple question, I know there is no clutch cover gasket, however it says to use THREEBOND 1207B, but I found Threebond Liquid Gasket 1194, would that one work also or should I go with 1207B?
Thanks
During my poor guy days, I used to use any heat resistance silicone liquid gaskets and never had any problems or leaks. If you put the 1194, let is dry and it does not work, the worst possibility is to remove the clutch cover and try another liquid gasket. Or just make a call to Threebond to determine the difference and see what's their opinion. I'm not familiar with Threebond so I cannot give you a precise answer.
Three bond is the duck's nuts. Get the right one if you can, surely any decent autoparts store will have it, otherwise online if not in a hurry. Its not cheap though.
Actually purchased 1207 B Threebond yesterday. Thanks all for the help!
