1 - 9 of 9 Posts
hi guys ive been a idiot and moved my throttle position sensor to get to the cam chain tensioner and now the throttle response is really bad ,i have treid moving it back and forth but its still bad ,any ideas on how to reset it
thanks
You can try searching the forum as there was a guy a year or two back that removed his TPS and had to fix it through trial and error. I believe he did manage it though.
you might have to go to a dealer for this one, not sure but think you have to hook it up to a honda nostic test pin box to get it in the right place.......
Or you could set it and try it, adjust and try and so on.
on my 12r it was a case of setting rpm to around 2k with the idle speed adjuster
and then move the tps until it revs to around 3k or best rpm and tighten screws.
note you dont touch the throttle.
try that and see if it sorts it
hth
1 - 9 of 9 Posts
