Ok guys my left fork on my 98 900rr is leaking so lets hear some opinions on what I should do.. .
Go with aftermaarket forks?.. . Do a stock rebuild?.. . What about a custom setup with aftermarket springs?.. .
I've never messed with forks before so lets here it guys whats the word. . .
Check the fork to make sure there is no scoring or rough spots. Assuming it's clear, then new fork oil and new seals (both sides).
But an upgrade, say using all the bits recommended and available from Race Tech would be something that I, too, would like to try.:smilebig:
what everyone said above and get the correct rate springs for your weight, and if you want to get better performance on the track, a revalve by a good suspension guru.
Thanks everyone this is very helpful and much needed as I cant stand not to ride.. . untill then :alcohol:
