1 - 20 of 21 Posts
The Pirelli Diablo Corsas are coming to the end of their life on my 1000RR. This time round I'm going with the same tire as I won't be changing the front but what are the opinions out there on an alternative for track/road use. Well no track use but fast road riding with no speed limits.
Also, has anyone tried riding with a 180?
ST.
Lots of folks have used the 180 as it gives faster turn-in. I haven't tried it yet. For the type of riding you describe, the Diablo Corsa is excellent, as you know. Other options would be Michelin's new Pilot Powers. Bridgestone makes some good tires, too. I haven't been keeping up with their latest...something like BT014 now? A cheaper alternative is the Metzeler Sportecs M1. If you search, you'll find a ton more suggestions, I'm sure. :)
I would stay with the Pirelli Diablo Corsas if I were you. Pirelli seems to be making the baddest tire for the baddest habbits of street riding. :devil:
I just put a 180 Pilot Power on my 929, and I like it. It does give the bike a different feel. It pretty much falls into the corners now.
I also have a 1000RR and didn't change the front when I did the back. I went to a plain Diablo to see the difference. So far the grip is a little less and the jury is still out on mileage. I would however recommend you go ahead and do the front. Mine needed it in another 1K anyway and have matching fresh skin would be worth the small loss of miles on the front. (Unless you really spin the backup on turn exit you should be similar)
cool, i'm looking for grip, couldn't care less about the mileage!
The old CBR600RR used to come with the Mich pilot sport which is a cool tire.
Any more advice out there on the 180s? Going from 600RR to 1000RR there is a big difference in turn in, I thought because of a heavier bike and damper but am wondering how much difference the 180 would make. Downside?
Also might be because the guy who owned the bike before me seemed to have done 1500km in a straight line from what I can tell.
Anyone had ago at these new dual compound jobs?
ST
I have had a set of the PilotPowers. The front tire didnt have enough edge. I would run out of tire when in a turn, so it basicly would limit my lean angle. The rear tire had plenty of edge for the corners though. The center coupound was to hard. May help get some extra miles out of the rear tire, but the front would wear just like a regular tire (because the front doesnt wear fast in the center anyway, usually). Also because of the hard compound the tire would spin when going WOT sometimes, and would lock up when braking a little easier. But the softer outter compound is sticky enough for the corners. I must say I like the idea of a multicompound tire. But I didnt like the PP's. I would ride a PP rear tire just cause it did stick enough, but I would stay away from any PP front tires.
A) The Pilot Power is not a multi-compound tire - only the Power Race is.
B) If you are running out of tire leaned over, you are most likely running too high a tire pressure, and/or not getting off the bike enough.
C) Get your suspension set up properly if you have not already done so - make sure your suspension geometry is right before you start blaming the tires.
D) You can get any tire to break loose on a high-hp litre bike. Learn better throttle control.
yeah i didn't read that properly either, i can't imagine running out of tire on the front but having plenty left on the rear.
I think you just put your foot in your mouth, or am trying to start some verbal battle.
1)The PP's are a dual compound tire, atleast I read somewhere they were. And the edge of the tire does heat up differntly than the center. :idunno:
2)Dont have any problems with running out of tread on Pirelli's
3)My suspension is set up properly
4)The PP would spin while I was in a straight away. While other tires seem to hook up. :huh:
5) :squid:
Your blame shifting arguement will only sound convincing to the squidly
I'm not here to start a verbal battle with you. Sorry if my post sounded a bit harsh. You can choose to take my advice, or ignore it.
Fact is, the regular Pilot Power is not a dual compound tire. The new Power Race is actually the first dual-compound tire homologated for road use.
I also find it hard to believe that you find the PPs 'hard'. They are 6% softer than any other tire in their segment, and are grooved over less than 12% of their surface area. There is plenty of nice sticky rubber available to hook up if you are not hamfisted with the throttle. Are you using tire warmers, or giving the tires time to warm up? (if you are comparing these to non-DOT, track-only rubber, that's a different discussion altogether - I'm discussing street tires for the original poster)
Your suspension may been set correctly for the Pirellis, but did you change it to compensate for the different tire profile of the Michelins? If not, that's possibly why you are running into problems.
Before you go around calling people squids, maybe you should realize that some people are willing to help, and accept that maybe you don't know everything. I know I certainly don't.
I've seen guys practically scrape their blinkers off, running the regular Pilot Powers, and they seem to have plenty of rubber left on the edges up front.
There's a huge difference. I switched to a 180/55 after wearing down the stock rubber, and now it turns like the 600RR, with a lot of extra power. The thing steered like a dumptruck with the 190/50.
For track use, I've heard great things about the new 190/55 profile as well, but haven't tried a set myself yet.
If you look at the shape of the front versus the rear tire, you will see that physics demands that the rear run out of contact patch before the front.
Pilot Powers offer the highest lean angle of any street tire. (check with Michelin, I believe its 55 deg.)
Pilot Powers are not multi-compound. Power Race's are.
If your locking up the rear tire on a regular basis you may want to learn how to use the front brakes and/or check your pressures.
What pressure do you run anyway ?
Seoultrain, I would recommend you change out both tires at the same time.
Do the "fingernail" test on the front tire you want to keep. I would bet your front tire, although having a lot of tred left, is pretty hard.
What do you mean by this comment?
How long do a set of Pirelli Diablo Corsas last on 04/05 Blades?
I know it depends on how harsh you treat them and how hard you ride but approximately what amount of k's should you expect?
Whats a front and rear Pirelli Diablo Corsas worth?
So is there much difference between the diablo and diablo corsas?
1 - 20 of 21 Posts
