1 - 2 of 2 Posts
I have a Toby damper that I got off of Hman (Thanks again).
I have it mounted against the frame with the tank mounted on top as I have seen before and what makes sense looking at the set-up. The problem is that the tank is loose and I can feel it vibrate as I ride. Both allen screws are tight. What I want to know is this normal and if not what have people done to fix it.
Thanks
Thanks
The tank is rubber mounted, so it should wiggle a little.
1 - 2 of 2 Posts
