1 - 20 of 43 Posts
ConqSoft : Is there a formula to figure out how many you need, based on your weight, to prevent them from ripping out?
from the faq at suspension.org:
How much weight can a single hook handle?
This question is almost impossible to answer as each kind hook has a different load capacity. The most common 10ga through 8ga gauge stainless fishhooks normally hold about 80 pounds static weight with little or no flexing. If the suspendee swings during a suspension the force on the hook can change dramatically (the dynamic load generated will be much more than the static weight of the person and the rig). Hooks are always a crucial variable that must be tested.
As for skin, different areas of the body handle weight differently. For example the back can hold over 250 pounds from one point, where knees seem to rip at around 100 pounds. Depth of the piercing can also play a dramatic role in tearing. The hook needs to be placed where the body's weight is evenly distributed over the hook. If the hook is placed too deep, the skin will bunch up causing the entire pressure to be placed on the entrance and exit points, conversely, if the piercing is too shallow, the force is focused on one point.
edit: we rule of thumb it at about 50lbs per hook....
To each his own dude, but I don’t understand why? What does it prove? is there a record for suspending ones self that you’re in search of?
I have a high tolerance for pain, but I don’t see the need to prove it in such a way as you do I guess. Please point me to your path of enlightenment so that I can understand this act of........…………………………………..what?
Discussion Starter #17
roadrunner954 : To each his own dude, but I don’t understand why? What does it prove? is there a record for suspending ones self that you’re in search of?
i did it for personal reasons. it does not prove anything. nor am i out to break any records.
it is not easy to try and explain it....
Despite that many people won't be able to get their heads wrapped around what drives you, I'd like to say publicly you're still a-okay in my book Critzy.
1 - 20 of 43 Posts
