Dynoed mine with 3000miles on the clock completely stock and got 63.7ft-lbs of torque and 119.9ponies.
Mine had est 7000 and I had 128.2 Hp and 66.6 lbft torque.  This was with a Full Hindle system with a very bad map.  I know that I have more power now from this new map that I'm using but haven't had a chance to have another dyno run on it yet.  Hopefully soon.
BTW I'm running a 12.5 air/fuel ratio from 4200rpm on up to the rev limiter. At 3100rpm I've got 17.5 air/fuel and at 3350rpm it starts dropping until it gets to the 12.5. Just in case you were curious about that.
thebackdraft : BTW I'm running a 12.5 air/fuel ratio from 4200rpm on up to the rev limiter.  At 3100rpm I've got 17.5 air/fuel and at 3350rpm it starts dropping until it gets to the 12.5.  Just in case you were curious about that.
you need a PCIII...
Z...
