Anybody know of a web link for applicable torque settings for the 09 Blade?
If not, does anyone with the manual like to pass along the torque settings for the front brake calipers?
Time for a winter clean as the salt has been nasty lately. Ta.
I have an 08 Blade and these setting should be the same I presume?
I am also having to change the front discs (due to someone trying to steal the bike and snapping the discs to remove the disc lock)
Do you know the torque values Nm for the following:
Front Axle
Front Disc Fixing Bolts (x6)
Your help is much appreciated..
Larky
Front Axle
Larky
Front axle bolt 79NM
Front brake disc bolts 20NM (The manual says to use new bolts)
