1 - 16 of 16 Posts
Anyone know of a place i can find almost all the specs online?
til then...I need the torque on the front sproket...also, is that reverse threaded?
:eek: they are in there? ;) Yeah, I found the whole thing on line one time in a PDF...just cannot remember where....
I am too cheap to lay out the 80 bucks...when I know its out there...somewhere..... LOL
ah yes, rule 5...Good thing I never asked anyone to do that. I am most likley going to get it off ebay anyway. they seem to be cheap "REAL" manuals on there from time to time.
so...torque settings anyone?
ND4SPD said:
Does Ron Ayers have it in the microfiche? :huh:
Nope.
SMTB, the torque spec on the sprocket bolt is 40 ft-lbs. I don't recall it being reverse-threaded, it would be the same as on any 929/954, and the manual didn't specify it on the page I looked at to get you the spec.
Common Torque Values
Front wheel Socket Size
Brake caliper mount bolt (loc-tite) 22 ft/lbs
Brake pad pins 13 ft/lbs
caliper bracket to forks (loc-tite) 36 ft/lbs
main axle 43 ft/lbs
axle pinch bolts 16 ft/lbs
front brake disk bolt 14 ft/lbs
steering stem nut 00-01 76 ft/lbs 30mm
steering stem nut 02-03 101 ft/lbs 41mm
triple clamp (upper & lower) 20 ft/lbs
Rear wheel
main axle nut 94 ft/lbs 32mm
sprocket nuts 47 ft/lbs
front sprocket 40 ft/lbs
rear brake caliper bolt 17 ft/lbs
MISC
exhaust pipe joint nut 9 ft/lbs
fuel feed hose banjo bolt 16 ft/lbs
fuel feed hose nut 16 ft/lbs
footpeg holder bolts 20 ft/lbs
Mori Link bolts 33 ft/lbs
oil drain plug 22 ft/lbs
oil filter 19 ft/lbs
showmethebombs said:
Thanks guys!
Pete, you rule man! :)
You're welcome! :thumb:
ST, I wouldn't expect anything less from you! :D
1 - 16 of 16 Posts
