1 - 17 of 17 Posts
So finally got back to working on the bike, ordered my parts and got them in, changed regulator -- went smoothly. Now fun part, stator. I went to remove the cover and as expected another problem, my socket is too big for the one last bolt :crap: after putting this aside out of frustration having to buy a whole other set for that one little bolt when the rest came off fine... I came back from Florida, nice and relaxed bought the new smaller socket set and back at it I go, I took out the old one, rebolted and installed the new one.. Bike won't start. Noticed this new tube/pin on the floor and realize. I didn't have that on the floor before :nono: now I take off the cover, put it in but when I put in the pin and try to match it up with the whole it goes it the stator goes in but gets stuck because it's not on correctly. The pin lines up but everything else doesn't, the bolts to the cover don't match where they're supposed to be and I looked closer and it doesn't seem to look flush. The little gear with the hole for the pin looks off and looks like the pin should be going deeper but it isn't and that's causing The miss match, I feel if the gear was moved accordingly to follow the hole behind it, I would have the pin in and the stator cover back on fine. I'll attach a photo, please help me, first bike I'm actually working on so I never looked at the inside of a stator cover..
This is from my 1999 900RR. I'm only assuming they're similar. It looks like your gear is in backwards, and the larger cogs need to engage the clutch on the inside of the flywheel. Give it a look.
Also, you almost need to get the hole lined up AND both sets of cogs on the first shot, because when/if the starter clutch moves it makes it hellish to line back up again. Once the gear is lined up, put the pin in first, then put the cover on.
Put a socket and ratchet on the flywheel nut and turn the motor CCW a little, and slide the starter gear up at the same time. The hole should be lined up so you can install the pin.
I've had my stator cover on and off so many times that I can do it with my eyes closed. That is the best way I've found to line that little gear back up.
Also make sure the alignment dowel(s) are clean and not damaged.
In the manual I have here it looks like the idler gear is located the other way around on the 929/954.
I don't quite understand exactly what the OP's problem is though? Align the idler gear with the hole in the crankcase, insert the pin through the gear to the bottom of the hole and then fit the cover.
This is the 929, showing front to the left. Which by his photo shows he has his idler gear in backwards.
I haven't touched anything on this at all other then the cover, and the setup is looking exactly like mine however my pin isn't going in as deep. I'm gonna try what Atimm693 mentioned and hopefully I can get this stator working. Thank you for the response !
Will try that later on today, thank you ! I'll update a little later on when I give it a go
Banned
To install shaft, move stator and either watch the holes line up or move away from the hole. It has to ride on the stator gear, right? And direction wise, flat side I would assume is to the engine?
This is the starter clutch IPL for a 929, to muddy the waters even more. It shows the larger gear inward.
http://www.bikebandit.com/oem-parts/2000-honda-cbr929rr-starting-clutch/o/m2073sch97103
Tried it and bam, works like a charm. Now my next issue, my fan doesn't turn on and the bike shuts off at 215f ish, 212+ but I have a crack in my airbox and the inside is somewhat exposed is this causing the fan to not read the correct temp or something where it doesn't turn on? Or is there something I should check regarding the fan
The air box problem is not related, but you'll want fix it to prevent dusting your engine if it's cracked before the air filter.
The fan is controlled by the switch in the radiator. Pull the wire off and ground it with the key switched on. If the fan runs, the switch is not working. If it doesn't, could be the fuse, relay, or fan motor.
Discussion Starter #13
Ready have the no airbox I just wanted to make sure if I needed to order anything So I can do everything in one shot :smilebig:
Would the fan be the reason it shuts off on idle ?
I'm not sure if a 929 will shut itself down if over heated, but 215 is not that hot. 230-240 is when you should start to be concerned, and an automated shut off should be even higher than that. So I don't think that is the cause of your stalling.
Discussion Starter #15
Could it be that the battery isn't fully charged yet? Even with the new stator/regulator ? Battery was practically dead before I put on the stator and jumped it with my car
I wouldn't think so, the charging system should be able to keep it running with no battery at all. Could be wrong though.
1 - 17 of 17 Posts
