1 - 17 of 17 Posts
Banned
it may us existing hardware on the bike. for one i think since you won it you should pay. but, you may not have all the oem hardware. correct me if i'm wrong, but wasn't yours moded before you purchased it??
No, I purchased a fully stock 2000 929RR :idunno:
It's still equipped with the OEM under tail.
I'm still trying to find out what under tail this is....
Banned
oh, my bad, i was thinking of another guy whose undertail "fell" off. anyway, i would check to see if you can find the same one on another website. hotbodies etc....and see if it is right. maybe see if he can give you the original part number and manufacturer.
I have researched many 929rr tails, i cannot recognize this one.... :crying:
Banned
Definately pay, you bid and one the auction. More than likely it will work with your existing hardware. You may have to cut your stock undertail and this will "bolt" on directly below.
Break Lites: Eurobikes GP style tail light
ok this is my best guess, and this is the tail i originally wanted, just could not afford it... seems to me the owner hacked into it and installed built in turn singals under the tail, if so the original GP tail DID come with a lock relocation kit, and this tail was disscontinued!... ill pay for the item now and contact eurobikes.com
That looks similar to mine minus the Signals ?? On the bottom??? Mine used all the stock parts and i did not have to cut down the rear of the trunk
is ur pic up to date? of the black 929... cause the undertail on ur black 929 is somewhat different - look at the spacing between the two round lights
No, I am the one who had the undertail fall off. I ordered the mototeck full undertail for mine. I think it will look good. Anybody got one already??
You can see the hole in it that would be for relocating your lock. However, you are supposed to ask all questions before you bid. If you don't like the answer then don't bid. But if you win an item you can't decide to not pay just because you didn't ask the right questions first IMHO.
eBay Motors: 2001 CBR 929 UNDERTAIL (item 120114258793 end time May-01-07 08:34:12 PDT)
ok I just won this undertail off ebay, and I asked the seller twice if the undertail comes with hardware, lock relocation etc...,
he reply with; it uses your original trunk.
Now I'm not sure if i should send the money for this undertail because he is not giving me information about it.
I think what he is saying is that it uses the original trunk lock, but you will need to relocate it. It's looks like a similar set up to mine.
Discussion Starter #14
yes but relocating it... what type of hardware is installed? thats the part i dont understand... i know the same lock is used but how can it still open the latch without the hardware it comes with, can i just rig something? :idunno:
either way it goes u definantly want to pay for it like everyone said should have asked questions first i hate it when someone does that to me
1 - 17 of 17 Posts
