Hi everyone. First sory for my bad english! Recently am trying to bring back to road cbr929 2001 non hiss model. This bike dead. Dirty and nasty since 2 years ago. So i manage to
- clean all mes up on wiring ans connector. Fuel rails. Injectors. Throtle body. Fuel tank. Fuel pump.
- fix the ecu by feeding 9volt ti pink wire from ig switch to ecu this the main prob due to prev owner tryto install hid lamp and accidentaly cut this wire
- i got good cranking. All spark new good and firing. Good fuel priming. New oil. Fresh coolant. Good output sprays from injector as i clean it before
- new battery. Servo still attach. Mil stay light since before dump for 2 years and it being running normaly
- re check everything all connector to injectors and spark plug are correct base on manual.
- i even clean by vakum cleaner by long hose to suck all dirt from piston blok. Then i spray a bit of oil of each cyl.
All those done. But still hard to startnot even a minute i saw sometime fire coming through throtle body kicking back.! But still no run.
Pleaseee
any suggestion. Sory again for my english.
Thx in advance..
Pleaseee
Thx in advance..
