So I dont know if im placing this in the correct place:idunno: so dont rip me for it just lemme know and ill fix it if its need thanks.. a lil help would be nice if at all possible.
As title says im trying to find specs on some velocity stacks for an 01 929rr.. Im taking a machining class and would like to see if i can make some while im here.. If you are able to get measurements such as inside/outside dia, taper per foot and any other small detail it would be greatly appreciated.. If at all possible take pics at what is being measured or make a blue print with specs in the thousanths
Why not get a set on ebay (OEM ones are cheap), and do all the measuring yourself? I'm sure you won't get as much credit if everyone else is doing the work for you ;)
heh - just noticed the original post is 3 years old :crap:
Is your question how do you change from OEM to race stacks? If so, just take the top of the airbox off - everything else just unscrews.
