Hi all,
I have a Hornet CB600F from 2002, but I think the engine is from 1999.
Could somebody with a similar engine please post a picture which shows exactly where the vacuum hose coming from the fuel tap (for opening the membrane in the tap) is connected on the engine? I'd like to verify what I did
Thank you!
Hi all,
Thank you!
I'll be honest, our 600 team is pretty thin right now, post a pic of what YOU did and maybe we can confirm that your placement is correct
Hi Ian, thank you for your reply.
From the left side of the bike, between carb 1 & 2:
(pics should be viewed in portrait, not landscape ;-) )
That's where I have it for my 900, which is very similar. I see near 3-4 there is another brass nipple. Does that one have a hose or at least a block off on it? If not, you should cap it because it's an intake leak if not. I think where you put your fuel tap hose is right on.
