New owner noticed the bike vibrates and chugs a fair bit below 4k rpm even when revving through e.g. from idle through past 4k it vibrates then smooths out a bit. Bike is in a good state of tune flapper mod not done yet.
Is this sort of vibration normal?
hi
if you set the throttle valves up correctely it will help and gets rid of a lot of the low down surging you get with sp's
have a look on the cd manual as it gives you the relevant info as you need to set the 2 cylinders up right
hth
