1 - 15 of 15 Posts
Administrator
I shot some on-board video (Sony TRV27 miniDV) with a 480 line resolution helmet cam.  When I play the video using the camera hooked up to the TV the quality is superb.  However, when I capture it to my computer using the DV (highest quality) mode and than burn it to a cd in the VCD format the quality goes all to hell.  The picture becomes very blocky and blurry.  Is there some other format I should try burning it in or is there something I'm doing wrong?
The videos Flasher shot last year at Grattan look much better (resolution/quality wise) than mine.  What gives?
TIA...
I'm not 100% about VCD format, but here goes...
From memory, VCD is recorded in about the same sort of quality as a regular VHS tape (ie - crap) so, you are getting about 250 lines of resolution as apposed to the 400plus you are actually recording in.
Haven't tried it yet, but there is a format called mini DVD (or something like that) and it basically saves your vids in 500 lines plus (depending on your format - NTSC/PAL etc) but on a regular CD rom - so basically, you get about 15 minutes worth of footage per CD rom.
Now, as for whether pinnacle can store it in that format, I got no idea, but I'll be finding out soon when I start converting my ride vids to CD rom...
Z...
Here's your problem - VCD.
The standard is pretty low compared to what you recorded it in, so between the low res, and the high compression, you end up with a crappy result. For universal playback you could try SVCD. For PC playback try DIVX or Quicktime.
For universal, good quality, there's really only one answer - DV on to DVD...
Whatever it is, figure it out by the weekend....I want to see some cool vids of you blasting by me in Lexington...
Edit:
BTW, I have scrapped my video plans for now. My video camera is just too heavy to be stable on the road. I'll pick the project back up when I get a modern camera that doesn't weigh so much....
Administrator
2OHOH2954 : Here's your problem - VCD.
I don't think the DVD player for our TV plays SVCD...not sure but will check it out. Can SVCD be played on a PC? Does Studio 8 offer the DIVX and Quicktime formats? I suppose I could look into a DVD burner...
I was hoping I could just burn some copies and send them to some friends.
Thanks for the help...Zeeman too!
Administrator
Baketech : Whatever it is, figure it out by the weekend....I want to see some cool vids of you blasting by me in Lexington...
Edit:
Working on it....
I mounted the helmet cam under the headlight on the front fairing and kept the camcorder in the trunk wrapped in foam. I'm amazed at the quality of footage...no shakes or jiggles and the picture is crystal clear. One caveat though...my wife watched the video and was noticeably freaked out when she saw just how fast we were riding!
Red Rider : One caveat though...my wife watched the video and was noticeably freaked out when she saw just how fast we were riding!
LOL...I hear you!
I decided to test mine out while Michelle was out of town....that way she couldn't blast me for it...
Administrator
ConqSoft : Quote (Red Rider @ July 14 2003, 1:37pm)I mounted the helmet cam under the headlight on the front fairing and kept the camcorder in the trunk wrapped in foam.
Careful.  Your front fender WILL hit it when riding hard.
I wondered about that, but there are no signs of contact after a full day of hard braking/riding around Grattan.  Thanks for the advice...I may move it just to be safe.
Red Rider : Quote (ConqSoft @ July 14 2003, 1:43pm)Quote (Red Rider @ July 14 2003, 1:37pm)I mounted the helmet cam under the headlight on the front fairing and kept the camcorder in the trunk wrapped in foam.
Wow. I nailed mine at the gap, street riding.
Has your front end been redone? Mine was stock, with full preload. (I weight about 155lbs)
thread un-hijacked.
Generally, you need a good software DVD solution to play SVCD. PowerDVD or WinDVD should be able to play SVCDs.
SVCD from what I understand, is basically MPEG2 video stream with MPEG1 audio. I read that before, but dont' hold me to it.
Studio 8 should allow creation of a DVD compatible MPEG file. However, it is kind of stupid in the way it handles it.... I had problems using a third party app to author a DVD from the file it spits out - however, on a PC with DVD decoder it was fine.
From Make Movie Tab > MPEG > Settings > Make MPEG File > DVD Compatible.
You'll get a huge .MPG in the end with DVD-like quality.
Administrator
Discussion Starter #14
ConqSoft : Has your front end been redone?  Mine was stock, with full preload.  (I weight about 155lbs)
Yep...the DK special! That must be the difference as I just checked it again after reading your post and there is no sign of contact with the front fender. I weigh 185 lbs. btw...
Administrator
Discussion Starter #15
asiliat : thread un-hijacked.
Thanks asiliat. I do have WinDVD installed on my PC so I'll give it a try. Does that mean that if I make a DVD compatible MPEG disc I will be able to play it through a DVD player or a PC?
You'll have to understand, I'm still trying to figure out how to program my VCR!
1 - 15 of 15 Posts
