so i just got a 86 vulcan 750. bought it with needing the carbs cleaned. so i cleaned them(even though they didnt need to be)
and got everything back together. tried to start the back and it wont start, it turns over, but wont start. its got good gas, its getting gas, the spark plugs are all good.
why isnt it starting? please help!
update
so i shot some starter fluid in the carbs and it fired up a very little but not much
so whats going on?
ok,so you cleaned the carbs ,its has good gas its getting the gas and the plugs are clean..do you know if the all the plugs are getting a strong spark to them???
also when i first take my 96,1100 shadow out of storage it doesn't want to fire up either i put jumper cables to my car and fire it up tht way to make sure i have a real strong spark..
hope this helps abit for ya...:idunno:
a little late but from my experience with mine yo either left and electrical connection off or you did not secure all three hoses to the fuel tank. the vulcan uses suction feed instead of the standard gravity feed so all of those hoses need to be snug to work proper
also if you used anything less than 93 octane the Vulcan becomes a major PITA
