Replacing the radiator and hoses on a 94 Blade, was going very well till I took the small oil cooler hose off - disaster !
The small pipe crumbled - tbh the corrosion was so bad I think it would have fallen apart if I hadn't touched the hose
109454
Was very apprehensive about undoing these 2 bolts but managed to get the whole thing off using a blow torch etc
Fiddly with the headers still in place ^^
Looking on the various Honda parts sites it seems you can't buy this item any more - they stopped making them sadly
Question to you guys - is the CB900F item close enough to use ?
It looks identical in the diagrams and is still available to buy
109455
109456
Discussion Starter · #2 ·
I took the gamble of just ordering the Hornet pipe which is still manufactured - then received a mail saying out of stock after paying ^^ classic web store stuff :)
After 2 weeks it showed up today with the O ring and new bolts - phew ! looks almost identical, with the mounting points and block facing area a good match - the only difference is a slight angle change to the main exit pipe
I'll take some comparison pics tomorrow - you never know - someone else may face the same problem
Discussion Starter · #3 ·
Comparison photos - working on rear wheel currently, but I'll let you guys know how well the hose fits when I get a chance to put it on
109575
109574
