Can anyone help me the other when I went out on my bike a mate notice water coming from under my bike. I've found out where it is coming from its coming from a thing called a coolant union. It's where the top hose from the rad joins the engine (it's a cover which I was told is a coolant union) there is a smaller hose that goes into the oil filter surrounding. Where the small hose fits into the coolant union the metal bit has broken off and i can't find anywhere to get a new one. Any ideas please
I had this on an old blade years ago, it's a water and road salt trap and corrodes through, then snaps under pressure.
You can buy it as a new part from your dealer or David Silver, or I just got one from a broken bike. I couldn't see any way to repair this to an acceptable standard without limiting flow.
You will 100% definitely need the O-ring that seals this to the block.
JOINT, WATER
19063-MW0-000
O-RING (50X2.5)
91305-KK3-830
