Ok rookie question. I have a 97 CBR 900rr. What type of socket do i need to get these caliper bolts off and split the calipers. There is no tool kit and I have completely lost patience with tool depts.
not 100% sure on the 900 but it should be a couple of regular hex head bolts to get each caliper off then a torx bit to split them apart
edit: I just checked the microfiche, up standard hex head and torx bit bolts
Yep, all caliper bolts should be torx. Be sure to loktite them when you put them back together.
