1 - 11 of 11 Posts
got a little problem, at the back end of my bike on the side is dripping yellow sticky resin type stuff, seems to be dripping from the bottom of the little black box (cdi?) when i clean it away it comes back when the bike is hot after riding.. its getting on my nerves!!
i could try to take the back bodywork off but looks hard to get off. anyone got an idea if its a big problem or seen this before? thx
that is the resin inside the cdi (used to seal and keep dry the electrical components)by the sounds of things,if its getting hot and melting then that really isnt a good sign,either the cdi is on its way out and over heating or you've got to much power going through it wich in either case by now will probably require a new cdi (wich unfortunatly arent cheap).might be worth checking your regulator as well because if thats the problem that would need fixing first or you'l have the same problem again
id check the regulator first,but even on ebay for a second hand cdi ther about 40 pound and the same for regulators,sorry to be the bearer of bad news
:( dammit il check the reg/rec sounds like its gona be expensive. thx for the reply.
Paul, which side is this on? If it's on the right side (exhaust) then it's the reg/rec. If its leaking from the black box on the left side, then it's the Cdi.
Surf
yea Surf its the cdi put a picture up so u can see, the bike runs fine will try to get somchai to check the reg/rec for me which is 2 years old according to the date wrote on it. Think im gona order a new cdi and rec/rec off ebay 50 quid , and 35 quid from hong kong. cheers!
the reg rec is positioned under the seat right ontop of the exhaust! lol daft place to put it?
Absolutely it's a daft place to put it, but Honda's not alone. I've heard some guys have tried putting cooling fans on them, but with mixed results.
i havnt got that model iv got the nc23 so its on the other side but surely it wouldnt be to much hassle to move it on nc29 would it?
i think its normally on the side but my bikes been modified a bit, probably gona maje the reg/rec an annnual service part to replace :D lol
1 - 11 of 11 Posts
