96 CBR 600 f3, It only makes this sound sometimes. It kind of goes away when I adjust the idle or the choke, and goes away almost completely while the throttle is engaged. It's a metallic vibration sound from the front right. I've gotten a few people say it could be an exhaust spring, and another said maybe lifters? I know it may be hard to give me an idea without hearing but anything is appreciated.
It goes down when I adjust the idle. It gets louder with more throttle. After riding a bit, I turn it off, IF i try to start it again withing 10 minutes or so, It struggles to start. In the mornings, I have to almost fully choke it to get it started, why? Also, after about 20-30 minutes of riding, I can feel quite a bit of heat from the motor, is this normal?
On the poor starting try checking the plugs/changing them or it could be the carbs might req. cleaning or adjusting ie. balancing.
Hope thats brought some idea's for you.
