1 - 1 of 1 Posts
I have a 1995 CBR900RR and I'm wondering if a '96-'99 CBR900 tank will fit onto my frame, of course with a little modification due to the fact the the old style 900's had a single bolt mount up front and whereas the newer models to '99 have the double mount bolt front. Anybody ever done this? Will a newer tank sit on the frame rails right? Seems like it should, and that the only issue should be that the front mounting hole problem needs to be addressed, but then also the early models had a fuel pump and the later gravity fed, would that make a difference as well? Thanks for any input in advance!
Chris
1 - 1 of 1 Posts
