Typically when electronics go bad, they just stop working. Is that what happens when PC goes bad? Or does it get srewy with the map?
I can connect to it, load different maps which change how the bike runs. The lights work.....
I'm trying to track down an issue and want to rule out the PC. But I'll start another thread about that.
Thank you,
I did. I was just curious how u would know if it was bad. The bike runs good without the pc but not nearly as good as it did before I started having fuel mixture issues.
Ive no idea of PC3 failure rate im afraid, might be better off dropping dynojet a mail to see if there are any on board diagnostics. Failing that im sure someone on here will know.
