I really hate to post somthing like this but its really the only way to get a fair amount of input
I'm looking at getting a 07 CBR 1000RR..
-it is a insurance salvage,
-laid down on the left... little rash on a engine cover and a little on the frame
-needs the left side inner and outer plastics, upper, and a headlight (i have everything but the headlight)
-no key so i don't know if it runs or if it does, if it has any mechanical problems (probably end up replacing the ignition)
-salvage papers...no title
was told the frame and subframe are straight. forks are straight, no beds in the rims, good rubber, good radiator, good chain, engine is has the right amount of oil in it and turns over(but has no key to verify if it starts)...basically all the damage is cosmetic according to the seller and once again i have a full set of plastics for this year of the fireblade
I know I will ahve to buy....
headlight - 200 USD
ignition- 50 USD
front turnsignals -30 USD
what do you think this bike is worth jsut with the listed points? ill work on getting pics
headlight - 200 USD
ignition- 50 USD
