1 - 10 of 10 Posts
We put a 2003 954rr in a race car and we're trying to get it tout run with out all the motorcycle stuff headlights turn signals ect... what is the min to make it run
Trimmed the wiring harness.
Do you have a Service manual for the 954? You'll get the wiring diagram in there. Or if you search here there's a dedicated thread to wiring harnesses.
You'll need the 954's ECU, CDI, Reg/rec, fuel pump, fpr to name a few things.
I don't know specifically, but there are things about the ignition that must properly function for the ECU to let the engine fire up.
Go the the fuel management section 6 in the Honda Svc Manual, read thru all the code faults, and I believe that will answer a lot of questions for you.
We just need to know what signal to give the ecm to start we think the green red wire needs to be grounded .. that should be it ... we took out the all the lights and stop engine wiring ..
1 - 10 of 10 Posts
