I mean just riding around the city Ive been changing up between 3-5k, does this seem about right?
Cheers,
TIM
Cheers,
TIM
Sounds way low. I tend to consider 4K a minimum and shift at 6-7K unless I am being a bit more aggresive. However a lot depends on what I am doing. For instance on a country 4 lane or interstate I might run it up to speed in third and go all the way to sixth to cruise. On a twisty hill I might run 8-9K in first. However the acceleration below 4K is very low, so I like to keep it above that so I can decelerate or accelerate to avoid issues.I mean just riding around the city Ive been changing up between 3-5k, does this seem about right?
Cheers,
TIM
I would think 3000RPM is too low.I mean just riding around the city Ive been changing up between 3-5k, does this seem about right?
Cheers,
TIM
That only happens if you shift at revs above max power.I would think 3000RPM is too low.
Shift when you're far enough into the power to not drop below it in the higher gear.
That would perhaps be so if I'd been talking about shifting at _peak_ power which I clearly wasn't.That only happens if you shift at revs above max power.
Ok - what was the "it" you were talking about??That would perhaps be so if I'd been talking about shifting at _peak_ power which I clearly wasn't.
"It" refers to the power referred to earlier in the sentence - I think it's a standard English usage of the word.Ok - what was the "it" you were talking about??
I read the sentence to mean "it" was the power in the current gear (seing that power was the last thing mentioned in the sentance)
In which case you would have to be above max revs.
Im guessing from your next posts that "it" is some unspecified min amount of power.
Because if "it" means the previous power, then what you are saying is"It" refers to the power referred to earlier in the sentence - I think it's a standard English usage of the word.
I can't see how you have a problem understanding it. Why would max revs or max power have anything to do with what I stated?
I understood what you ment blade easy enough to see what it stood for."It" refers to the power referred to earlier in the sentence - I think it's a standard English usage of the word.
Dicknose you are over complacating a simple sentance that has a obivious meaning, to much knowlage is not always a good thing. :huh:Because if "it" means the previous power, then what you are saying is
shift when you're far enough into the power to not drop below the previously mentioned power in the higher gear.
Im not quite sure what the previous power is? The power you have in the current gear?
That still seems to me to say you want the power after the shift to be at least equal to before the shift.
The only time you can shift gear and the power in the higher gear is equal to the power in the lower gear is when you shift after max power.
Maybe we are on completely different wavelengths on this.
Im an engineer and use the term power probably a bit more technically than most.
But your sentence seems very ambiguous.
The "it" references a power that isnt clear, its either self referential (power after shift is not less than before the shift) or its unspecified (power that after shift that not below some other power which itself isnt specified)
I took the meaning as self referential - which implies shifting after max power.
walks away dazed - amazing how such a simple sentence can cause so much confusion!
I've been thinking about it more since this threadFunny I never think about it
I keep the ZX6R around 6000RPM.
