1 - 11 of 11 Posts
Where is the catalytic Converter located on the CA model 954? is it in the stock can, or the mid pipe past the HTEV?
as far as I know its in the exhaust just before where the end-can bolts on. you'ld probalby gain more power though through a PCIII rather than just dumping the cat, imho
When you pull the pipe off you will be able to see the honey-comb inside the pipe if it's a cat.
There are three cats on the California 954. Two mid pipe under the engine and one in the stock exhaust can. A full system takes care of the problem nicely.
1 - 11 of 11 Posts
