1 - 2 of 2 Posts
Been having issuea with my rear indicator and headlights not working. I managed to get it to work by manually wiring between the green wire on headlight and negative. Ive traced all the greens to the joining bit by the relays behind the screen but where do they earth to frame? The earth from battety to framr is good but high resistance on headlight earth to frame. Im thinking its under tank somewhere but lifted tank and xouldnt see it. Cheers
The blinkers, headlight, cluster, etc combine to one green ground wire up front and then travel back to the rear frame spar through the wire harness.
Take your seat off, lift the rear of the tank up, and there you will find several grounds attached to rear of the frame with a small bolt in the middle of the spar:
1 - 2 of 2 Posts
