big bore kits
You mean pistons.
Wiseco and JE should list +1mm piston sets but it is expensive boring and replating the block.
Or you could run 954 pistons which give slightly more compression as well.
Just buy a 954 engine, it bolts right in. Bigger bore, higher compression, lighter pistons, slightly hotter cams, bigger throttle bodies, better injectors... it's basically universally better.
I agree. I just don't think boring the 929 has enough bang for buck. Building the engine yourself you'd likely spend US$1200 just to get 25cc which is hardly significant.
