Dear friends,
I recently bought an 06 Firebalde. Now I want to get it serviced, but I dont know which lubricant is the best.
I am planning to change the fork oil, brake fluid, coolant, oil and the spark plugs.
Any help will be appreciated.
Dear friends,
Whats the milage on it?,services are usually every 4000 miles,with a big service at 16000 miles(valves and plugs filters ect).If you dont have the hand book to check the grade of oil .I would go with10-40 semi synthetic most brands should be fit for the job,just depends on how much you want to spend.
Discussion Starter · #3 ·
It's on 18.000 miles. I guess it still has its original pluıgs in it. :thumbd: I already changed the oil / oil filter and the brake pads. As I said i want to change the plugs with NGK iridiums for other fluids I need suggestions from experienced owners :)
