So, this is a continuation of a thread I made a month ago. I still haven't figured out the problem and so the bike is still down.
Long story short, the bike just shut off while idling perfectly normal after riding about 40 miles with no apparent problems. Went to turn it back on, and fuel pump would not prime.
So, I've gone through the checklist - the fuel pump is OK. fuses are OK. Relays are OK. All that is left is the Bank angle sensor (called lean angle sensor in the wiring schematic) and the ECU. I performed the test to see if the bank angle sensor was working properly, and it is not i.e. with it plugged in and key to ON, if I tilt it 60 degrees, it does not click like a relay. At first, this made me think I had found the problem - bad bank angle sensor - then I found out they were ~$100 and I put off buying a new one. Good thing.
I thought to test the wires going into the sensor. Attached below is the wiring schematic if any of you know how to read it better than I. The green wire should be ground. It is a ground that is shared with other things like all the lights, etc. The other two wires that go into the sensor are power wires.
When I tested these wires, I was very confused to find that with my multimeter's negative lead on the neg. lead of the battery, if I checked for voltage on the green wire (ground) it sees 12 volts!!! I then realized that all of the other things which also use the green wire for ground - like the turn signals and headlight and taillight - also do not work when key is ON.
So, what the hell could be causing this? A problem inside the ECU?? Please help me out. I feel like I've gotten to the point where I don't know enough to be able to fix this.
-Ryan
-Ryan
