Just wondering if the 1000rr forks with radial calipers will fit an 02-954,and will I need the whole front end or can I use my rim,rotors,and axle?Also will I still be able to keep my vortex top triple clamp and heli bars?
TIA
Alpine
After an extensive search and a lot of reading.I did not find a thing on the swap.Can someone point me in the right direction.Just trying to find out what parts I will need,if the forks will fit.
TIA Alpine
Sorry dude, was in a bit of a rush this morning when I replied to your post..
Heres the link http://www.fireblades.org/forums/honda-fireblade/46538-1000rr-front-end-954-a.html
I have done the conversion myself and it worked very nicely :D
Heres a list of what you will need:
1000RR forks
1000RR Radial calipers
10mm spacers if using 330mm 929/954 discs (got mine from Dan Kyle) Brad may also have them you will check with him?
And suitable brake lines, use a radial master cylinder and just use 1000RR lines or otherwise you will need custom lines or Gixxer lines so the banjos have the correct orientation :)
Any questions dont hesitate to ask.
Cheers Jai
thanks jungleboy thats just what I was looking for.Definately going to swap some of those on my bike.
