1 - 10 of 10 Posts
Discussion Starter #4 (Edited)
Which specific bolts are you talking about on the bike?
Ronayers.com Microfiche Honda>Motorcycle>2001>CBR900RR>UPPER COWL 1
Do you mean you forced a quarter-inch bolt into an M6 hole?
No im saying for my Frankenstein bolts on my 929RR i wanted to replace them so they dont stick out.. the quarter inch bolt slid in the washer and hole but obviously its not long enough to start threading.
I need to know what faring bolts from the CBR XX will go in those holes.
What are Frankenstein bolts?
In which holes though?
right next to the RR on the tail section they are also for straps and such..
they are on both sides.
Okay, and you want to replace them with normal bolts so they don't stick out?
I would guess they're M8 but pull one out and measure it.
The hook strap bolt is M6 X 1.0mm thread so the CBR XX one you show will not fit.
The length needs to be about 15mm long. The heel plate bolts are also M6 x 1.0 and 20mm long so they will fit & match the bike.
(ps most of the other Blade fairing bolts are m5 X 0.8mm threads so these won't fit).
so which bolt do I need? Do you have a part number?
1 - 10 of 10 Posts
