Hi all, I'm new to the forum and I need some help.
I'm in the later stages of completing my 929 track/street project which I have built from the ground up (God bless ebay!).
I have used a standard 929 UK loom with a universal non-HISS ignition switch.
The ECU is a KEIHIN 38770-MCJ-671 9630-114115 which I believe is from a US spec non-HISS bike.
So far the engine cranks but I have no spark.
Will this set-up work or do I need to do some wiring mod's?
All help greatly appreciated.
Can't wait to give her a blast!
It won't work until you disable the HISS.
If you have one of the original keys just cable-tie it to the HISS sensor and use the HISS ECU.
I think it is possible to re-wire something to do away with the HISS but I don't know what it is, try searching the forum as I'm sure it's been posted in the past.
The best and easiest way would be to get a US harness as well.
I keep watch and watch..if I'm right with this..
kal said ...just pop up the wire that US model ECU need, then you can use US ECU to make your bike run...
This guy is fabulous ...
