I have got my rear in bits and I am greasing all the suspension linkages. However when I removed the plates and looked on the inside of them they are quite badly scored. Has anyone ever seen this before and what is causing it?
Missing pivot collar id bet. Its a sleeve for rear shock lower mount between triangles ..
Both collars are there. I am wondering if this is old marking when that has happened in the past?
The dog bone can move freely left/right on its bearing. On mine it picked a direction, and stopped against the plate. After that there is inevitable wear at that face. I really don't see a solution for it except using steel plates, so I just cleaned it and put it back together. You could put the worn face on the outside and start again, but I didn't.
If there's space for it?? Maybe a large washer each side would help, but its going to have to be a strange looking thing, like about an m14 fender/repair washer that's 1mm or less thick.
I stripped the rear end of my 97 RRV down yesterday and found exactly this. It has "Never" been taken apart and has no "Collars"/"Washers". Did you get yours sorted out?
Its how it is designed mate the centre spacer moves side to side. I just cleaned mine regreased and put it back together.
