1 - 9 of 9 Posts
Looking for a set of aftermarket performance cams.
Let me know what you have and what you're looking to get.
i have a set of cams a erion polished and ported head a 1033 case with 75 mm pistons an more just let me know what you need. I have just about every thing that is racing and oem. [email protected] or 205 447 7094
You can bore the cases 5mm over?
75mm pistons though make it 1024cc by my calculation?
yea you can bore them over. but yea a 75 mm do make a 1024 but pistons dont only decide displacement. its a 1033 i know
You can stroke the crank as well but that has nothing to do with the cases.
You could stroke the crank 9mm and the _standard_ cases would be 1031cc :)
The only combination of bore and stroke that equals 1033cc is if the crank has been stroked 0.5mm in addition to the 75mm pistons?
The _cases_ though aren't 1033cc unless the stroked crank comes with them?
The 1050cc cases you mentioned in the other thread - what size are those pistons?
they ar 76mm
76mm would make it 1052cc with a stock crank (same bore and stroke as the early GSXR1100).
Is the engine apart?
I'm surprised there's enough room to go 76mm - how much metal is left between the cylinders?
There is not much room at all. 76mm is really to big for that motor you can over rev one time or you will crack a sleeve. 75mm is the best i think. do you think that that could be something you could use
I wouldn't normally but it sounds pretty cool so I could be interested in using it for something.
Are you selling a complete engine or just the bored cases?
1 - 9 of 9 Posts
