Looking to buy and or trade for a 93-99 900rr motor bottom end in good shape. Any year any size (893 or 919). All I need is the block halves, the crank, con rods, and pistons.
Up for trade are two bottom ends with bad cranks, one extra transmission, one extra oil pan, one head complete (w bent valves), valve cover, two exhaust camshafts in good shape, as well as several other odd and ends that I haven't found a home for over the years. Such as a clutch basket w/o clutches, water pump, hoses, etc.
The second motor I put in it just spun a bearing and I need to fix this bike up and sell it ASAP. If I don't have any luck getting the motor fixed, the bike will be up for sale as is with spares after the body is done being repainted.
Thanks,
Jeff
Discussion Starter #2
Also, I would be willing to purchase entire motor assemblies, if that is what you have. The crank, block, con rods, and pistons are just the minimum that I need.
